Fuenkli Posted June 3, 2018 Share Posted June 3, 2018 I would like to automate the upload from my Goodwe 5048 ES GTI to the PVOutput.org website (I am doing it manually at the moment). I found this on GitHub https://github.com/markruys/gw2pvo I have only a very basic understanding of programming and do not fully understand how to implement this. Can someone please explain in simple language what I have to do, like required software/hardware etc. The inverter is linked to the Goodwe portal. Quote Link to comment Share on other sites More sharing options...
___ Posted June 4, 2018 Share Posted June 4, 2018 21 hours ago, Fuenkli said: Can someone please explain in simple language what I have to do, like required software/hardware Well, you're going to need something that can run python3. It runs on both Linux and Windows, so here you can choose whatever you feel comfortable in. This will also mandate the hardware. Personally I'd use a Raspberry Pi and run Raspbian on it. There are numerous sources on how to install software on debian based distributions (of which raspbian is one, hint: use apt-get), and what you'd need is "python3" and "python3-pip". With that installed, the README in that project becomes sufficient to get it going. I'm being a bit vague as I really really don't want to get into a "help me learn Linux" role here :-) Quote Link to comment Share on other sites More sharing options...
Fuenkli Posted June 4, 2018 Author Share Posted June 4, 2018 thanks for the reply Plonkster. Very much appreciated. I always wanted to learn more about Linux and Raspberry Pi (only worked with Arduinos so far). Now i have a good reason to start . ___ 1 Quote Link to comment Share on other sites More sharing options...
