Steve87 Posted June 28, 2023 Share Posted June 28, 2023 So a very interesting project on this site. Spent all but an hour consulting on this project with a client & to my horror after discussing a starting point of 5kW Sunsynk machine etc only to be shown a DB with 3 phase supply which makes for some interesting budget conversations etc. So we got to the conclusion of the best of both worlds & settled at the 8kW Sunsynk, with a 5kWh E-Tower & a 5.5kW Canadian Solar PV Array. The battery is below specification for this 8kW machine but another E-Tower will follow in time which I thought was a wise decision. So effectively we will have a Single phase backup & other 2 phases that will be shed when Eskom decides so. Basically 1 essential phase & Non essentials phase, the other 2 stay on eskom. Why is this installation quite clever in a good way? because the inverter will not trip when the Eskom Grid is there because the inverter can pass through. When it loadsheds they are limited by 5kW of the battery. But this 8kW potential is unlocked when more storage & power arrives in Phase 2. Will post picks of the finish product tomorrow. WannabeSolarSparky and Jacques Ester 2 Quote Link to comment Share on other sites More sharing options...
Scorp007 Posted June 28, 2023 Share Posted June 28, 2023 1 hour ago, Steve87 said: So a very interesting project on this site. Spent all but an hour consulting on this project with a client & to my horror after discussing a starting point of 5kW Sunsynk machine etc only to be shown a DB with 3 phase supply which makes for some interesting budget conversations etc. So we got to the conclusion of the best of both worlds & settled at the 8kW Sunsynk, with a 5kWh E-Tower & a 5.5kW Canadian Solar PV Array. The battery is below specification for this 8kW machine but another E-Tower will follow in time which I thought was a wise decision. So effectively we will have a Single phase backup & other 2 phases that will be shed when Eskom decides so. Basically 1 essential phase & Non essentials phase, the other 2 stay on eskom. Why is this installation quite clever in a good way? because the inverter will not trip when the Eskom Grid is there because the inverter can pass through. When it loadsheds they are limited by 5kW of the battery. But this 8kW potential is unlocked when more storage & power arrives in Phase 2. Will post picks of the finish product tomorrow. Even the DB wiring is a masterpiece spotity and Steve87 2 Quote Link to comment Share on other sites More sharing options...
Steve87 Posted June 29, 2023 Author Share Posted June 29, 2023 Must say this is the cleanest, neatest DB I have seen anywhere. These guys have taken good pride in their work. Im under pressure to replicate... Jacques Ester 1 Quote Link to comment Share on other sites More sharing options...
spotity Posted June 29, 2023 Share Posted June 29, 2023 That DB board makes me drool... Man! Quote Link to comment Share on other sites More sharing options...
Steve87 Posted June 30, 2023 Author Share Posted June 30, 2023 Massive 3 phase split & a Sunsynk 8kW Failure later we have this installation all but done. Some battery sprague only the missing piece of the puzzle come CoC inspection on Monday. Jacques Ester 1 Quote Link to comment Share on other sites More sharing options...
Steve87 Posted June 30, 2023 Author Share Posted June 30, 2023 Jacques Ester 1 Quote Link to comment Share on other sites More sharing options...
Jakac Posted June 30, 2023 Share Posted June 30, 2023 Freedom Won a very good battery. Absolute no issue. Recently bought one. Steve87 1 Quote Link to comment Share on other sites More sharing options...
Diabolix Posted July 3, 2023 Share Posted July 3, 2023 Any idea on the model number of the DB board? Quote Link to comment Share on other sites More sharing options...
Steve87 Posted July 3, 2023 Author Share Posted July 3, 2023 Sorry I haven't a clue all I know is that its a 45 way or 15 x 3. I have also bought them in the past & as far as I know MCE is the brand. Compliance certificate all wrapped up & we clear out. Jacques Ester 1 Quote Link to comment Share on other sites More sharing options...
P1000 Posted July 4, 2023 Share Posted July 4, 2023 It looks a lot like SBU, which you can get from voltex. https://britelighting.co.za/products/su3-samite-surface-db-board-3x15w I think there is a 3x16 DIN version as well. Quote Link to comment Share on other sites More sharing options...
Bobster. Posted July 4, 2023 Share Posted July 4, 2023 (edited) Why the change from LiTE to E-Tower? And can LiTE and E-Tower be run in parallel? Edited July 4, 2023 by Bobster. Quote Link to comment Share on other sites More sharing options...
Bobster. Posted July 4, 2023 Share Posted July 4, 2023 Interesting how you mounted the battery, which seems to go against the concept of building a tower with bus bars between the individual batteries. Clearly Freedom Won give that option - you wouldn't just drill holes in the casing of a brand new battery. Quote Link to comment Share on other sites More sharing options...
P1000 Posted July 4, 2023 Share Posted July 4, 2023 9 minutes ago, Bobster. said: Why the change from LiTE to E-Tower? And can LiTE and E-Tower be run in parallel? This is the only mention of LiTE in this thread, what makes you think it's a change? No, they have incompatible BMSs, so they cannot be run in parallel. Quote Link to comment Share on other sites More sharing options...
Bobster. Posted July 4, 2023 Share Posted July 4, 2023 11 minutes ago, P1000 said: This is the only mention of LiTE in this thread, what makes you think it's a change? No, they have incompatible BMSs, so they cannot be run in parallel. Previous installs that Steve has posted have used LiTE. So I'm curious. Uh... let me rephrase: My curiosity is aroused. Quote Link to comment Share on other sites More sharing options...
Steve87 Posted July 4, 2023 Author Share Posted July 4, 2023 I can only speculate that the Lite 5/4 Battery is a goner. Mainly because the E-Tower seems to have now become the FW popular affordable building block budget battery. This particular installation started off with the owners not even aware of the 3 phase Mains supply. So they based their planning & budget on the 5kW Sunsynk & a 5kWh battery. So after our initial meeting & site visit when I came across the 3 phase supply this was then communicated and made for a budget that was stretched to the limits. My suggestion was a 8kW Sunsynk for obvious reasons of a good amount of passthrough Current when no loadshedding. Then also a 8kW inverter backup supply when loadshedding. However, the budget could only stretch so far. So the compromise was the battery & then adding another E-Tower when able. So this is the best of both worlds. In the long run they will never regret the larger inverter. Batteries when come when they can to unlock the 8kW backup loads. Jacques Ester 1 Quote Link to comment Share on other sites More sharing options...
