Chris.P.Bacon Posted July 2, 2023 Share Posted July 2, 2023 Do any of you have experience with what fans are inside the SOL-I-AX-3VP? I want to order Noctua ones to replace the standard fans in the SOL-I-AX-3VP, but before I order it I want to know what size to get. Looks like an 80mm fan for the lager one, but the small one... I cannot figure out what size it is, doesn't feel standard? Quote Link to comment Share on other sites More sharing options...
Chris.P.Bacon Posted July 2, 2023 Author Share Posted July 2, 2023 I wonder if there is a different solution, maybe someone can mill a water cooling block for the inverter's components and then use an off-the-shelf water cooling kit for a PC. Quote Link to comment Share on other sites More sharing options...
