Volta Stage one BMS Software
Thank you for all the great info in this thread.
Wondering if I could ask a qq or 2 please. I connected to my master battery using the 6.1 software, as described, and have attached what I see.
  • I didn't seem to need a password. When I used a password, nothing seemed to change.
  • I adjusted the config file to read 2 batteries and was then able to see both packs.
  • Do the charge-discharge cycles seem high for a 1 year old system (1518/1503) and I wonder why they're not identical?
Thanks again for all the info. It's a shame this isn't exposed to and by the inverter.
P.S. I used this cable https://solar-assistant.io/shop/products/pace_rs232
Edited by splunker
  • Replies 65
  • Views 35.7k
  • TenMilSocket
    TenMilSocket
    All right, it is late and as usual I poked the bear until it woke up.... Here are my steps:  1. Rig up a USB to RS232 adaptor to connect to the RJ12 port as per the connection information be
  • The attached file was sent to me by the technical manager of africogroup.com - I have not tried it yet but it seems to be the same as the one shared on the Lux Power Facebook group. Hope it helps.
  • Successfully updates my Stage 1 to V15.52 today using a cable made with the instructions posted here 👍
Request. Will you send a link to the software? Thanks!
I hope this will help if there are still some people on this threat. I bought a 14.3kwh Volta stage 4 battery from Leading Lithuim beginning 2024. They have sent me the attach firmware upgrades and I hope this will help. They only blind spot I have is will I need to take the battery offline before upgrade the software?
stage 3 updater.zip Volta firmware updater stage 1 & 2 new.zip
I had 2x Volta Stage 1 batteries in parallel since May 2023 with firmware v15.44. They were reaching 100% charge together with all cells balanced within 30mV, but the packs SoC drifted apart as the batteries drain, with pack 1 on 25% while pack 2 drops to 20%. The state of health on pack 1 was 100% and pack 2 96%, so pack 2 is now accumulating higher DoD.
The supplier suggested I need a firmware update, so last night I updated them both to v15.58 successfully (each completely isolated and dip switches off), have yet to see if the SoC drift fixes itself but at least the inverter reports the average SoC instead of alternating between the 2 like it did before. Only possible issue is the cycles count for both batteries went up 10x and I'm not sure if that is just the new scaling factor is 0.1 instead of 1? Over a period of about 10 minutes pack 1 went from 260 to 2600 and pack 2 from 249 to 2498 and then they stayed there since, will give it a couple more days and see.
Hi. I'm struggling with my setup..
Deye5kw and 2x Volta Stage1 Pro batteries.
I turned everything off, connected battery power cables, disconnected the comms cable from the inverter, then connected the link cable into the one battery IN port, the other end into the other battery OUT port, and connected the comms cable to the PCS port on the battery where the OUT port is now occupied. Turned on the battery with the PCS one first, the leds do a good green KITT impression and settle. Then I turn on the second battery, both batteries doing a Cylon impression with the green lights switching left right and eventually settling. I turn on the inverter and it starts up after about 2 mins.
I am not able to communicate proppperly over the canbus to read the battery states. The LCD on the inverter doesn't show two batteries. These batteries don't have dip switches and are aparently smart and can set their bus address themselves.
What am I doing wrong?
There are no instructions on how to connect the second battery of this type. The Deye and Solarman apps allow control sort of. I'm worried I'm damaging the batteries.
Please can someone advise
Just got a new system installed with 5kw Deye inverter and 2*stage1 Volta battery. Facing a weird issue, where everything works fine, but when the battery reaches 100% Soc the BMS page on the inverter stops displaying the Charge/ discharge values.
When the sun goes down, the inverter pulls from the Grid instead of the batteries. Then I have to manually restart the battery and then the inverter starts pulling from the battery.  Has anyone had similar issues?
Should I try to update the battery ?
  • 5 weeks later...
Anyone that has the latest firmware for the Stage 1?
Would also like to know if there is an update for the Stage 4 since in the year I have had mine I see it only goes up to 98% and it had one drop out a couple of months ago.
Did you manage to sort this out.
I own a Wulills 5kWh battery with a Vkingner BMS, which is the same as in the Volta. BMS Tools works, but I'm struggling with connecting the battery with my Victron Multiplus II GX and with my other battery with a JK BMS. I've tried many protocols using BMS Tools, both CAN and RS485 but without success. I used the pin-layout suggested by the Volta manual shared in this thread.
  • 4 months later...
I've reverse engineered some of the RS232 communication with my Wullils BMS. I expect that this script also works with the Volta BMS. Feel free to try and improve the code:
https://github.com/iisquazar/Vkingner-QDT-Wulills-BMS/blob/main/qdt10wd-to-mqtt
All you need is a raspberry and run the python3 script. It will report measurements via the commantprompt and via MQTT if you have a working MQTT broker.
  • 10 months later...
On 11‏/7‏/2023 at 08:52, HendrikBigChief said:
الصورة أم الكود الفعلي؟
On 28‏/8‏/2024 at 15:42, Karel van Reenen said:
لديّ برنامج المرحلة الرابعة، لكن حجمه كبير جدًا بحيث لا يمكنني نشره هنا. أرجو تزويدي بعنوان بريد إلكتروني لأتمكن من إرساله إلى أي شخص يحتاجه. لديّ الإصدار 13.8A
On 14‏/12‏/2023 at 10:26, Skillet said:
On 12‏/9‏/2024 at 18:05, RaeesD said:
كان لديّ بطاريتان من نوع فولتا المرحلة الأولى موصولتان على التوازي منذ مايو 2023، مع إصدار البرنامج الثابت v15.44. كانتا تصلان إلى شحن كامل بنسبة 100% مع توازن جميع الخلايا ضمن نطاق 30 مللي فولت، ولكن حالة شحن البطاريتين تباينت مع انخفاض الشحن، حيث كانت البطارية الأولى عند 25% بينما انخفضت الثانية إلى 20%. كانت حالة البطارية الأولى 100% والثانية 96%، لذا فإن البطارية الثانية الآن تعاني من انخفاض أكبر في مستوى الشحن.
اقترح المورّد أنني بحاجة إلى تحديث البرامج الثابتة، لذا قمتُ الليلة الماضية بتحديث كليهما إلى الإصدار 15.58 بنجاح (كل منهما معزول تمامًا ومفاتيح DIP مطفأة). لم أتأكد بعد مما إذا كان انحراف حالة الشحن (SoC) قد تم إصلاحه تلقائيًا، ولكن على الأقل يعرض العاكس متوسط حالة الشحن بدلًا من التناوب بين القيمتين كما كان يفعل سابقًا. المشكلة الوحيدة المحتملة هي أن عدد دورات الشحن لكلا البطاريتين قد ازداد عشرة أضعاف، ولستُ متأكدًا مما إذا كان ذلك بسبب أن عامل القياس الجديد هو 0.1 بدلًا من 1؟ خلال فترة عشر دقائق تقريبًا، ارتفع عدد دورات الشحن في البطارية الأولى من 260 إلى 2600، وفي البطارية الثانية من 249 إلى 2498، ثم استقر عند هذا الحد. سأنتظر بضعة أيام أخرى لأرى.
On 13‏/7‏/2023 at 11:23, thoquz said:
أعتقد أنه يتحدث عن برنامج إدارة المباني المذكور في الدليل والذي يسمح لك بتغيير البروتوكول بحيث يمكنك استخدام ماركات أخرى من أجهزة العاكس.
 Do you have firmware version 15.55 for a Det Power 5.12 kWh, 51.2V battery?
