Assistance with solar panel spec
Hi Guys,
I have a small inverter 1500w(12v) and 12v lithium battery. I want to get a solar panel but not sure what to get. I have attached the spec of the inverter, if someone can please advise me ?
inverter.pdf
Edited by AviSA
  • AviSA changed the title to Assistance with solar panel spec
2X 400 watt panels with max 50v open circuit voltage
Wired in 2P configuration
JA Solar 410W Monocrystalline PERC Half-Cell MBB Black Frame MC4 - About R2300 each
37.32 V Voc
13.95 A Isc
That should do the trick.
Maybe some will give better options :)
For starters 1 of those panels may be enough, depending on how big the battery is ( AH ).
Edited by WannabeSolarSparky
37.32 V Voc
13.95 A Isc
Thank you. Battery 100AH
