alkafak Posted June 30, 2018 Posted June 30, 2018 Hello Everyone, Please if you have experience to mounting Infini Solar 3KW+ int he wall, please tell to me, i am very happy if somebody share the pictures, i see not equipped baracket for this product Thank You Allkafak Quote
Mark Posted July 1, 2018 Posted July 1, 2018 Hi @alkafak Page 6 of the manual gives you the dimensions for the 4x mounting screws. Don't go light weight... I went coach bolts This works very well. Just get someone to help you a the unit is heavy!! Regards Mark 1 InfiniSolar-2KW3KW-manual-20150310.pdf Quote
___ Posted July 1, 2018 Posted July 1, 2018 7 hours ago, Mark said: Page 6 of the manual gives you the dimensions for the 4x mounting screws The inverter doesn't ship with suitable screws? :-) Quote
Mark Posted July 1, 2018 Posted July 1, 2018 (edited) I think it did but I wanted more length for my soft old farm walls... so my own size plugs and screws... overkill but... Edited July 1, 2018 by Mark ___ 1 Quote
___ Posted July 1, 2018 Posted July 1, 2018 3 hours ago, Mark said: overkill I kinda like using 8mm coach screws if there's any weight involved, eg these ones. But the Multi ships with two thick-ish stainless steel (or looks like it at least) screws that sits very snug in a 6mm drilled hole so I've never had to do this engineering myself. Mark 1 Quote
alkafak Posted July 2, 2018 Author Posted July 2, 2018 all of the Master, Thank you for reply my thread, i will try which the pass for the inverter caused the bolts not included in the package Alkafak Quote
SilverNodashi Posted July 2, 2018 Posted July 2, 2018 19 hours ago, plonkster said: The inverter doesn't ship with suitable screws? :-) nope. Sadly they don't include bolts. The 10KVA unit does have bolts though, weird. I normally use m8 rawl bolts, unless the wall is soft, then chemical anchor comes to play Quote
Mark Posted July 2, 2018 Posted July 2, 2018 I think its a great thing not having bolts... just suggested sizes and strengths... Every wall is different and I wouldn't want to hang 30-50kg off a wall with bolts that were not appropriate for the application. My 2c anyway ___ 1 Quote
Chris Hobson Posted July 2, 2018 Posted July 2, 2018 2 hours ago, Mark said: I think its a great thing not having bolts... just suggested sizes and strengths... Every wall is different and I wouldn't want to hang 30-50kg off a wall with bolts that were not appropriate for the application. My 2c anyway Covering for Voltronic? Mark 1 Quote
Guest Posted July 2, 2018 Posted July 2, 2018 29 minutes ago, Chris Hobson said: Covering for Voltronic? What a refreshing post. Quote
___ Posted July 2, 2018 Posted July 2, 2018 2 hours ago, Chris Hobson said: Covering for Voltronic? Truth be told, I think he has a point: Use the correct screw. The main reason they include screws is likely because the case and bracket is aluminium and if some idiot uses the wrong screw to hang it with you'll get galvanic corrosion and it will drop from the wall. Oh, and these things life on boats, yachts and barges, so even more important. So its to protect people from themselves, or that is my guess. Chris Hobson and Mark 1 1 Quote
