July 11, 20186 yr 4 hours ago, zaroky said: Needs to find vmii refl[a]sh tool It's in the files section of this forum: I see that there is also the firmware for a VMIII model. They almost certainly use the same reflash tool, so if you have trouble opening the .rar file (I use 7-zip, a free download, just Google it), you can open the .zip file for the VMIII by double clicking on it, and use the UPSReflashTool.exe from that zip file.
July 12, 20186 yr Author The zip isn't the problem the prob is that I haven't the isuu to download the file
July 12, 20186 yr 3 minutes ago, zaroky said: I haven't the isuu to download the file If you post 1 more (total 5) then you will get download rights - so reply to this then you can download.
September 25, 20195 yr 15 hours ago, Arsalan said: How to download inverex vmii firmwear I believe that there is Axpert VM II firmware in the files section of this forum. But Inverex inverters seem to be a bit different to other Voltronic Power manufactured inverters; I suspect that they have customised firmware, at least in some cases. The firmware on this forum is fairly old now, I'm guessing 1-2 years, and you have not said why you want the firmware. So: it may be older than what you have, it may not be customised for Inverex hardware, and it might not work at all. Plus, from 3 posts ago, you might need more posts before you can download. Perhaps you can rack up a post or two answering some of these questions.
