zaroky Posted July 11, 2018 Share Posted July 11, 2018 Needs to find vmii reflush tool Quote Link to comment Share on other sites More sharing options...
Coulomb Posted July 11, 2018 Share Posted July 11, 2018 4 hours ago, zaroky said: Needs to find vmii refl[a]sh tool It's in the files section of this forum: I see that there is also the firmware for a VMIII model. They almost certainly use the same reflash tool, so if you have trouble opening the .rar file (I use 7-zip, a free download, just Google it), you can open the .zip file for the VMIII by double clicking on it, and use the UPSReflashTool.exe from that zip file. zaroky 1 Quote Link to comment Share on other sites More sharing options...
zaroky Posted July 12, 2018 Author Share Posted July 12, 2018 The zip isn't the problem the prob is that I haven't the isuu to download the file Quote Link to comment Share on other sites More sharing options...
zaroky Posted July 12, 2018 Author Share Posted July 12, 2018 Many thanks for your reply coulomb Quote Link to comment Share on other sites More sharing options...
pilotfish Posted July 12, 2018 Share Posted July 12, 2018 3 minutes ago, zaroky said: I haven't the isuu to download the file If you post 1 more (total 5) then you will get download rights - so reply to this then you can download. ibiza and zaroky 1 1 Quote Link to comment Share on other sites More sharing options...
zaroky Posted July 12, 2018 Author Share Posted July 12, 2018 Thank you very much Mr pilotfih Quote Link to comment Share on other sites More sharing options...
Arsalan Posted September 24, 2019 Share Posted September 24, 2019 How to download inverex vmii firmwear Quote Link to comment Share on other sites More sharing options...
Coulomb Posted September 25, 2019 Share Posted September 25, 2019 15 hours ago, Arsalan said: How to download inverex vmii firmwear I believe that there is Axpert VM II firmware in the files section of this forum. But Inverex inverters seem to be a bit different to other Voltronic Power manufactured inverters; I suspect that they have customised firmware, at least in some cases. The firmware on this forum is fairly old now, I'm guessing 1-2 years, and you have not said why you want the firmware. So: it may be older than what you have, it may not be customised for Inverex hardware, and it might not work at all. Plus, from 3 posts ago, you might need more posts before you can download. Perhaps you can rack up a post or two answering some of these questions. Quote Link to comment Share on other sites More sharing options...
