Chris Louw Posted July 24, 2018 Share Posted July 24, 2018 TTT I will be your apprentice . Some of the skeletons now climbing out the cupboards . SECRETS Quote Link to comment Share on other sites More sharing options...
Guest Posted July 24, 2018 Share Posted July 24, 2018 (edited) 3 hours ago, Chris Hobson said: TTT you're still an amateur. Ya recon ... you should have seen the 200w panel's connection box after I re-wired the 2 panels from parallel to series. If I did not have software to check the volts when I got back down, and back up that fast, that panel would not have lasted much longer. EDIT: Panel was piping hot, burnt my hand, the other panel "cool" in the midday sun in comparison. Edited July 24, 2018 by Guest Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted July 24, 2018 Share Posted July 24, 2018 7 hours ago, The Terrible Triplett said: Ya recon ... you should have seen the 200w panel's connection box after I re-wired the 2 panels from parallel to series. Quote Link to comment Share on other sites More sharing options...
Youda Posted July 24, 2018 Share Posted July 24, 2018 7 hours ago, The Terrible Triplett said: Ya recon ... you should have seen the 200w panel's connection box after I re-wired the 2 panels from parallel to series. TTT, what was the root cause? There was some bug in the wiring, yes? Quote Link to comment Share on other sites More sharing options...
seant Posted July 24, 2018 Share Posted July 24, 2018 So is the guys pump working or not , cause I think we've scared him off Youda and Chris Hobson 2 Quote Link to comment Share on other sites More sharing options...
Guest Posted July 24, 2018 Share Posted July 24, 2018 2 hours ago, Youda said: TTT, what was the root cause? There was some bug in the wiring, yes? Root cause ... haste. The rules I learnt that day:Rule 1: It is not recommended to alter anything on a blistering hot Saturday midday, when you have to SIT on a metal roof, on top of a double storey house.Rule 2: Even less advisable to take a break on said hot day, in a air-conditioned room. (you have to go back up)Rule 3: And it is never ever advisable, to quench ones thirst, with one Castle Light whilst sitting in the air-conditioned room. (false sense of completion) 2 hours ago, seant said: So is the guys pump working or not , cause I think we've scared him off I hope @Buckworth has seen that we are quite a happy bunch here. Quote Link to comment Share on other sites More sharing options...
___ Posted July 25, 2018 Share Posted July 25, 2018 5 hours ago, The Terrible Triplett said: with one Castle Light Should have had a beer instead... Chris Hobson 1 Quote Link to comment Share on other sites More sharing options...
