Axpert 5KVA with 60A MPPT with Pylon Tech batteries
RobG
 Share
Hi Guys
I'm new to the forum needing some advise please.
I  have an older Axpert 5KVA with 60A MPPT 12x250W PV. I need to replace my 4x100A/H  Batteries which are toked after 3 years abuse.
Can anyone recommend the Pylon packs? Do they work with the older Axpert?
I know that I would need 2 packs to start as you can only draw 1.2Kw at a time. I draw a pretty constant 1.8Kw with everything running.
The specs seem great on paper.
They look good with cycle life and apparently you can add packs as you can afford them.
Are they a better option than BYD plus or what would you recommend?
Any help greatly appreciated.
Thanks Rob
 Share
