Gabriël Posted August 3, 2018 Share Posted August 3, 2018 i just switched to icc v 1.5.0 and get this info, i rebooted it twice and also switched the disconnect twice, still same info re the grid - and it flickers red. there is power on the grid but icc indicates zero volt but plenty watt. your thoughts please. Quote Link to comment Share on other sites More sharing options...
Sidewinder Posted August 3, 2018 Share Posted August 3, 2018 (edited) That's why I log into the pi, make a backup of the previous version, then press the "point of no return" UPGRADE button. When there are funnies like this, I can rollback. Edit...and don't go for S/W with a version 0 at the end, perhaps. Edited August 3, 2018 by Sidewinder Gabriël 1 Quote Link to comment Share on other sites More sharing options...
___ Posted August 3, 2018 Share Posted August 3, 2018 3 hours ago, Sidewinder said: That's why I log into the pi, make a backup of the previous version, then press the "point of no return" UPGRADE button. With Venus (the ccgx firmware) the storage is split into multiple partitions, and new versions is loaded alternately on these partitions so that booting the previous one is easy: Just tell the bootloader to boot the other one. You can always switch back and forth between the last two. This is a really good way of doing it. The software for this, swupdate, is on github. It works best with u-boot, but you should be able to make it work with the native pi loader. Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted August 4, 2018 Share Posted August 4, 2018 Can you confirm, with a multimeter, how much volts are present, and at what frequency? Quote Link to comment Share on other sites More sharing options...
pilotfish Posted August 4, 2018 Share Posted August 4, 2018 On 2018/08/03 at 9:02 AM, gabriel said: i just switched to icc v 1.5.0 and get this info, @Manie knows about this bug and has already released v1.5.1 which addresses it. Quote Link to comment Share on other sites More sharing options...
Gabriël Posted August 4, 2018 Author Share Posted August 4, 2018 SOLVED thank you @Manie for fixing the bug! also thanks for diverse tips and suggestions re this bug from members of he forum. God bless! Quote Link to comment Share on other sites More sharing options...
