Posted August 8, 20186 yr I am trying to use Victron connect to monitor 1 x MPPT and 2 x BMW 702 in the same installation from the same pc. VC using VE cables , but the software doesn't always see the different devices. sometimes sees only one, then after closing and reopening it, is sees a different one and at best it will see 2 devices at the same time Anyone with a different approach using the same hardware or maybe someone had this issue and found a solution. Any help would be appreciated.
August 8, 20186 yr You should report it. I know the guy who writes the software (he's not Dutch :-) ).
August 8, 20186 yr I was going to say we are indeed fortunate to have Mr Victron as part of our community but he has arrived.
