GershV Posted August 13, 2018 Share Posted August 13, 2018 Hi All I have 2 inverts in parallel 1 x 4000va/5000kw model sol-i-ax-5m firmware-72.40 U2- 1.24 1 x 5000va/5000kw also model sol-i-ax-5m (think this one is actually a sol-i-ax-5p) firmware-72.61 8 x 220 AGM batteries 4 in series and in parallel with another 4. 8 x 260w solar panels on the roof all connected to the 4000va/5000kw also known as the pf0.8 They were not able to connect in parallel so I contacted the supplier and the send me firmware 72.61 to downgrade the new pf 1.0 machine and 72.70 to upgrade my old machine. After the fact I read that these two versions are not compatible either so I just took the old one back to 72.40. I am not to sure if these are the best firmware for the two machines and now my batteries just go up to 50.3v max Can I maybe use the same firmware on both machines? Which firmware will be best for AGM batteries? Hannah Barnes 1 Quote Link to comment Share on other sites More sharing options...
