Namzy Posted August 29, 2018 Share Posted August 29, 2018 Hello I'm new here. Please can the Axpert Mks 3kva 24v work with tubular batteries like the luminous lt500 2x 12v 220ah batteries. I have been hearing that they won't charge well. I know there will be problems with equalization but still cant seem to understand why it won't charge at least till float. Thanks Quote Link to comment Share on other sites More sharing options...
___ Posted August 29, 2018 Share Posted August 29, 2018 18 minutes ago, Namzy said: tubular batteries I had some trouble finding a charge voltage for this. It seems you should not charge at less than 15.5V in the absorption phase, which is 31V on a 24V system. This is the point where this particular inverter cuts out. As I recall, it won't let you get close to 30V on charging. So it seems what you heard is right: this is probably not a good combination. Quote Link to comment Share on other sites More sharing options...
Namzy Posted August 29, 2018 Author Share Posted August 29, 2018 11 minutes ago, plonkster said: I had some trouble finding a charge voltage for this. It seems you should not charge at less than 15.5V in the absorption phase, which is 31V on a 24V system. This is the point where this particular inverter cuts out. As I recall, it won't let you get close to 30V on charging. So it seems what you heard is right: this is probably not a good combination. Thanks for replaying. This is the best specs I could get after searching tirelessly. I want to buy the Iltt 220ah Quote Link to comment Share on other sites More sharing options...
