Gabriël Posted September 6, 2018 Share Posted September 6, 2018 hi gents, what is your take on this ups, see attached. i have 3 good 250ah sonic agm batteries which i would like to use with it. do you think it will be able to keep the batts at 100% soc? is the price of 7k [ex batteries and vat] for the 3kva unit too high? thanks in advance! Tescom-SSPro-range 2017-Jan (9).pdf Quote Link to comment Share on other sites More sharing options...
Jaco De Jongh Posted September 6, 2018 Share Posted September 6, 2018 14 minutes ago, gabriel said: do you think it will be able to keep the batts at 100% soc? Seems like it was designed to do so. Although the charging amps stated in the Data sheet is not what I would expect for a 250Ah battery, I guess they have designed it for keeping the battery at 100% SOC with an Occasional discharge. The adjustable Trickle voltage meets the standby volts of your Sonic's, but the Quick Charge voltage is a bit lower than the Cycle voltage of the Sonic's.. I guess it will function well as a backup.. Chris Hobson and Gabriël 1 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted September 6, 2018 Share Posted September 6, 2018 On UPS'es, the larger ones, the charge current is the marker. What this means (copied from the spec sheet), on a 36v bank, I'm not sure: 11A at normal line & normal temperature (Average) 5000 - 30A Rule of thumb: On a 12v inverter: 100ah battery, you need min 10amps. 200ah battery, min 20amps. etc. Quote Link to comment Share on other sites More sharing options...
Gnome Posted September 6, 2018 Share Posted September 6, 2018 4 hours ago, gabriel said: hi gents, what is your take on this ups, see attached. i have 3 good 250ah sonic agm batteries which i would like to use with it. do you think it will be able to keep the batts at 100% soc? is the price of 7k [ex batteries and vat] for the 3kva unit too high? thanks in advance! Tescom-SSPro-range 2017-Jan (9).pdf You may want to consider going for the Axpert King. It is effectively a online UPS. Comes in both a 3kVA (24v) and 5kVA (48v). Gabriël 1 Quote Link to comment Share on other sites More sharing options...
pilotfish Posted September 7, 2018 Share Posted September 7, 2018 7 hours ago, Gnome said: You may want to consider going for the Axpert King. It is effectively a online UPS. Comes in both a 3kVA (24v) and 5kVA (48v). I think Gabriel is trying to utilize 3x batteries after 1 failed if memory serves correctly. 12 hours ago, gabriel said: hi gents, what is your take on this ups, see attached. I used the same inverter for a long time which I installed when the rolling blackouts started to bite - it was great. I initially used a different unit which would often cause my PC's/TV's/Amps etc to restart at changeover but that stopped when replaced with this inverter. I removed it when I installed the PV system and it is now resting in my storeroom. The 5kVA unit has a 30A charger which is perfect for your bank - don't forget the battery balancer! Gabriël 1 Quote Link to comment Share on other sites More sharing options...
Jaco De Jongh Posted September 7, 2018 Share Posted September 7, 2018 7 minutes ago, pilotfish said: The 5kVA unit has a 30A charger which is perfect for your bank But the 5 kVa is a 48Volt unit, thought you said 8 minutes ago, pilotfish said: I think Gabriel is trying to utilize 3x batteries after 1 failed if memory serves correctly. Quote Link to comment Share on other sites More sharing options...
pilotfish Posted September 7, 2018 Share Posted September 7, 2018 Oops, you are correct - I have a 5kVA unit and it is 48V. The 3kVA is 36V but with 11A charger. The 3kVA would work fine as a UPS type backup system, but not for cycling duty. Quote Link to comment Share on other sites More sharing options...
Gabriël Posted September 7, 2018 Author Share Posted September 7, 2018 11 minutes ago, pilotfish said: it is now resting in my storeroom would you consider active service for it again? edit... you just mentioned it is the 5kva unit and 48v, so i cant use it... 11 minutes ago, pilotfish said: I think Gabriel is trying to utilize 3x batteries after 1 failed if memory serves correctly. jip, you're right. i now have 3x250ah monsters which in series will give 36v and can be used with an ups in my wife's practice. as power outages are not a daily occurrence i believe the batteries should last long in that environment. regarding the battery balancer, yes, i still have one and it will be used. pilotfish 1 Quote Link to comment Share on other sites More sharing options...
Jaco De Jongh Posted September 7, 2018 Share Posted September 7, 2018 1 minute ago, pilotfish said: The 3kVA would work fine as a UPS type backup system, but not for cycling duty. My thoughts as well.. Gabriël 1 Quote Link to comment Share on other sites More sharing options...
