malcolmp Posted July 27, 2015 Share Posted July 27, 2015 Hello all I have installed my 12v 100Ah Royal batteries - two parallel banks of 4 in series. At the beginning of the battery banks I have a 100Amp DC fuse - one for each. Is this too big, should it be 50amps each? Then I see from general chat that these RCT 5000VA Axperts hybrids, some people have installed an isolator switch between the batteries and the inverter. I just disconnect the batteries - but what switch should I be looking for? A make and model would be perfect then I can go to Current Automation or AC/DC and ask for a compatible. Quote Link to comment Share on other sites More sharing options...
Wetkit Posted July 27, 2015 Share Posted July 27, 2015 Getting a switch that can handle that lot could be asking a bit much. Rather get a fuse holder just before the invertor. You get some extra protection now too. Quote Link to comment Share on other sites More sharing options...
Mike Posted July 27, 2015 Share Posted July 27, 2015 You can go to Rubicon or ElectroMechanica and get a Merson DC Disconnect with 2 x fuse links of 125A each. I use them on most installs ___ 1 Quote Link to comment Share on other sites More sharing options...
