Posted October 10, 20186 yr Hi, I got a bunch of 100ah Long branded AGM batteries. I have connected them in series to a 48V Axpert 5K. I'm not sure if this is normal, but please see attached readings that I get from the batteries - is it normal for the batteries to be so different from each other. Way one - batteries in order from 1 to 4 Way two - swapped batteries 1 and 4 around and re-measured Thanks in advance for the help! Long 100ah battery test.xlsx
October 10, 20186 yr The figures don't seem that far off for the battery chemistry. It seems whithin reason to be equalized with a balancer. R Edited October 10, 20186 yr by Riaanh
