Growatt spf 5000 es bricked
Dannyuk
5 minutes ago, Dannyuk said:
The fan was noisy with no reason and i tried to make an upgrade.
What exactly did this "upgrade" that you attempted entail? Did you try a Firmware upgrade perhaps? What Firmware did you have and what Firmware did you use?
Have you tried to reboot whilst pressing the reset button?
actually i did realized that the battery was 2% charged. i used a lot of them which i found on the posts @. do you mean the black button on the left side(underneath)?
F030_SK041.05_20210701_A.bin F2809_ES_SK040.05_20210701_A.bin F2809_SK067.F4_20221027_A.bin V103_SK068.F4_20221027_A.bin F030_SK041.06_20220104_A.bin F2809_SK040.06_20220104_A.bin F2809_SK067.01_20220104_A.bin V103_SK068.01_20220104_A.bin
The different series Firmwares are not interchangeable.
Growatt in their wisdom has had four editions of the same Inverter up to now. The first two series were all Firmware 040/041. The subsequent series were the 067/068 and the latest ones are actually 113/114.
If you flash the incorrect series Firmware then yes, it is probably bricked.
If you know what the original Firmware was on yours, then perhaps you can try and reflash that series. Worth the try.
You would need 4 12V LA batteries in series to hook up to see if it will start up if you suspect a battery power supply issue.
You need to know your original series Firmware.
i.e. if your Inverter had 040 and 041 it will always be 040 and 041. They started off with 040.01 and 041.01. The last Firmware for that series was 040.06 and 041.06
Their controller board hardware changed over the last 2 years and that entailed new Firmware being rolled out together with the new hardware.
Have a look at this post from Aug 2022 that also contains the Growatt links to the docs.
hi again zsde. thanks for your nice explanation. how can i figure out about the software that it was on it? the inverter  is completely   stuck, bricked. there is no way to restart it. is there a label or a chip that could help me to figure  out about the software that it needs? thanks a lot in advance and sorry to bother you
Edited by Dannyuk
The match up of serial number and Firmware version is unbeknown to me.
The original 5000ES models had bespoke AC connectors sticking out at the bottom of the Inverter. Also it had two sets of parallel MC-4 connectors at the bottom.
If your's has that then it will be Firmware 040/041
The later models did away with those and all connections are now done with screw type terminals inside the bottom cover.
Perhaps check with Growatt International Rep if he can give you the Firmware version based on the serial number
You can mail or Whatsapp Amos in China
+8613267189226
[email protected]
Edited by zsde
+8613267189226
[email protected]
Mine are of the new type and are on 40/41, running perfectly for over two years.
Contact the technical support at Elleyhill Power phone 011 701 5200 they may be able to send you firmware 40/41.
follow this link.
Growatt SPF5000ES Firmware Upgrade — Elleyhill Power
+8613267189226
[email protected]
hi again. I did contact xian on whatsapp and he was very quick and advise me to change the control board. he said: if you tried the wrong upgrade(wrong software) you probably burn your control board. it wasn't true. i only download all the upgrade on the web 040and 041 which i flashed with but didn.t worked and i tried to flash with 067 and068. all good now it start working like dream. BANG ON. now the fan s not noisy and  looks good. thanks again to zsde for his nice explanation which helped me to understand a lot
