My inverter says I’m off grid
Candiceglaum
1 hour ago, Candiceglaum said:
How can I fix my DEYE sa version inverter that says I am off grid without it being loadshedding!?!? Please help
Could be something else, but one possibility is that the grid in your area is outside the acceptable Voltage or frequency parameters, and that the inverter is therefore swapping to battery operation to protect itself and your loads.
Can you give more info? Is this happening permanently or sporadically? Check Grid Setting screens (for high and low frequency, and high and low Voltage), and compare it to the reading on the Grid Detail screen (Refer to manual if needed).
