I am looking for an air to water standalone heat pump suitable for retrofitting to an existing geyser.
What reputable brands are available is SA?
I looking for a good value that has local after sales backing if at all possible.
Knowing what brands to stay away from will also be useful.
What are your experiences?
Edited by phil.g00
Hi Phil. I think you are Lucky, why? Because water temperature of your bore hole is the same than comfort temperature of a House.
Then, you can install a heat exchager for Heat seassons and a heat pump for cold seassons.
All brands I know work well, because that kind of machines uses yo be developments of Big brands.
When you install i'd be glad if you show real COP data of your system.
Edited by Javi Martínez
