Location of Backed Up Load Earth Leackage - question
Hi all
After having my change over switch fail on Friday (it only worked on the eskom input - fortunately) and replacing it I realised that my earth leackage after the inverter is wired as follows:
PS - I have three phase - so 2 phases are not backed up and one phase is used for the backed up loads.
My question is shouldn't the backed up load E/L rather be wired on the OUT of the change-over switch?  As it stands now it doesn't look like my backed up loads have any E/L protection when the change over switch is set to eskom/bypass?
The plug on the diagram is just an additional surface mount plug I had put in near the inverter.  This plug is obviously also not working when in bypass/eskom.
ie. should it rather look like this?
Also, should I perhaps have another 32A breaker between the inverter AC out and C/O switch?
Edited by Douw G. Gerber
