ICC Monitor Software
mervinpearce
Usually the axperts have a serial and usb output, mine came supplied with the necessary cables as well. If you want to use the serial you will also need a serial to usb port cable.
You should find the ports at the bottom of the axpert where all the other cables enter / exit the unit.
Edited by Arandoza
