Wind turbines connected with solar to an Axpert inverter
Frodo
You can so, connect the wind turbine directly to the batteries if the turbine has  3AC wires, you only need a rectifier to convert 3 phase AC to DC. But it only is adecuate for small turbines. In this case you need also to control the surplus of energy and some hardware to derive it...
I have a small turbine connected in this manner, no problems until now perhaps because is a dreadful turbine (😣)
  • 1 year later...
I have a 1000 watt HYE wind turbine. On it's plate it says 110 V. It has 3 wires and generates hundreds of volts on all 3 wires if I turn it with a drilling machine.
I don't have a charge controller for it but I do have a Morningstar TS 45 that can divert to a dump load.
I have a Axpert King 5kw and would like to connect the turbine to the batteries.
Can anyone give me some advice on this HYE turbine.
  • 1 year later...
On 2019/01/02 at 11:49 AM, SilverNodashi said:
No. Windturbes charge differently from solar panels and it might damage the MPPT. You would need a wind change controller, and I am not sure if it will cause problems, or damage to / with the Axpert.
Greetings Sir, Please advise me whether you have a solution to this challenge since I would like to connect a 500W 48v dc VAWT thru ito OWN MPPT controller into an existing 100A.hr LiFePO4 battery being charged from 2.6kWatt of PV panel power, this battery is driving a 5kW axpert inverter. Many thanks. Alan
