Warren Posted August 29, 2015 Share Posted August 29, 2015 Hi all So I am finally at a point where i can play with the software that came with my inverter. So I hooked it all up with a USB to RS232 converter. Everything seems to work. I can even hear the relay when I switch output source priority from utility to SBU. The issue I have is on the data logging I cannot select the device in the droplist. Its just not there. It does show the device ID on the main screen on the left Has anybody else experianced this Quote Link to comment Share on other sites More sharing options...
John Posted August 29, 2015 Share Posted August 29, 2015 I've got the same problem no logging on USB, haven't tried serial yet Quote Link to comment Share on other sites More sharing options...
Eugene Posted August 29, 2015 Share Posted August 29, 2015 Hi all So I am finally at a point where i can play with the software that came with my inverter. So I hooked it all up with a USB to RS232 converter. Everything seems to work. I can even hear the relay when I switch output source priority from utility to SBU. The issue I have is on the data logging I cannot select the device in the droplist. Its just not there. It does show the device ID on the main screen on the left Has anybody else experianced this Hi all So I am finally at a point where i can play with the software that came with my inverter. So I hooked it all up with a USB to RS232 converter. Everything seems to work. I can even hear the relay when I switch output source priority from utility to SBU. The issue I have is on the data logging I cannot select the device in the droplist. Its just not there. It does show the device ID on the main screen on the left Has anybody else experianced this You have the older inverter, the new ones have USB plug and play. The data/charts icon shows Device Mode, the dropdown list seems to be only for selecting unticked functions (others are ticked and greyed out). Select date then click on 'Browse' to see data or charts. Quote Link to comment Share on other sites More sharing options...
Warren Posted August 29, 2015 Author Share Posted August 29, 2015 You have the older inverter, the new ones have USB plug and play. The data/charts icon shows Device Mode, the dropdown list seems to be only for selecting unticked functions (others are ticked and greyed out). Select date then click on 'Browse' to see data or charts. Tried what you recommended but did not work. I have a drop down on the left that says select device. But it's empty. Quote Link to comment Share on other sites More sharing options...
Jackal Posted August 29, 2015 Share Posted August 29, 2015 Where did you install Watchpower? Some security policies in Windows prevent writing to folders located in Program Files and other protected system directories. In order for data logging to work Windows needs a writeable directory. Reinstall Watchpower in C drive or another directory you know your normal user account can write to. Alternatively close Watchpower from system tray, right click the icon while holding shift and select 'Run as Administrator' which may overwrite the security policy blocking writing to the disk. Quote Link to comment Share on other sites More sharing options...
___ Posted August 29, 2015 Share Posted August 29, 2015 Watchpower is an unfortunate name I think. Too close to WatchTower. No offence to any JWs :-) Gabriël 1 Quote Link to comment Share on other sites More sharing options...
Warren Posted August 29, 2015 Author Share Posted August 29, 2015 Where did you install Watchpower? Some security policies in Windows prevent writing to folders located in Program Files and other protected system directories. In order for data logging to work Windows needs a writeable directory. Reinstall Watchpower in C drive or another directory you know your normal user account can write to. Alternatively close Watchpower from system tray, right click the icon while holding shift and select 'Run as Administrator' which may overwrite the security policy blocking writing to the disk. I tried the run as admin. Did not work. I will re install quickly on c: I do have full admin rights but you never know with win 8 Quote Link to comment Share on other sites More sharing options...
Warren Posted August 29, 2015 Author Share Posted August 29, 2015 I'm a programmer so I am trying to find a RS 232 packet sniffer. I will then get all the requests and responses and map them. I will then write my own app for windows and for web including a way to calibrate all settings. Chris Hobson 1 Quote Link to comment Share on other sites More sharing options...
Jackal Posted August 29, 2015 Share Posted August 29, 2015 Lots of guys already playing with the code, here is some info which may get you going: http://theloadshed.blogspot.com/2015/04/advanced-communicating-with-inverter.html?m=1 Warren 1 Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted August 29, 2015 Share Posted August 29, 2015 I'm a programmer so I am trying to find a RS 232 packet sniffer. I will then get all the requests and responses and map them. I will then write my own app for windows and for web including a way to calibrate all settings. .....and then you going distribute to your mates and forumites. I can see the data on my setup and can download it as a pdf but cannot convert it to something useful (A csv file would have been good). Clement and Warren 2 Quote Link to comment Share on other sites More sharing options...
Warren Posted August 29, 2015 Author Share Posted August 29, 2015 Do not know what I did but it started working. The only difference I can see is that the first time I started it up it showed my computer name and below the device I'd. Now it shows my IP address instead off the counter name. Weird. So now if I select the drop box for the device it allows me to select the device. I am still going to write my own app. Thanks for the help guys. PS:I will sell it to you. Joking I will make it opensource license so you guys can play with it too Quote Link to comment Share on other sites More sharing options...
John Posted August 29, 2015 Share Posted August 29, 2015 @ Warren check my broadband there is a ruby script with all the commands and a pdf is available on the Australian electric car forum with all the commands Quote Link to comment Share on other sites More sharing options...
Eugene Posted August 29, 2015 Share Posted August 29, 2015 Do not know what I did but it started working. The only difference I can see is that the first time I started it up it showed my computer name and below the device I'd. Now it shows my IP address instead off the counter name. Weird. So now if I select the drop box for the device it allows me to select the device. I am still going to write my own app. Thanks for the help guys. PS:I will sell it to you. Joking I will make it opensource license so you guys can play with it too I was just about to post a pic with the IP address and Device USBxxxxxxxxx number below. Warren 1 Quote Link to comment Share on other sites More sharing options...
Jackal Posted August 29, 2015 Share Posted August 29, 2015 Glad it's sorted and keep us posted on the app. Warren 1 Quote Link to comment Share on other sites More sharing options...
Warren Posted August 29, 2015 Author Share Posted August 29, 2015 @ Warren check my broadband there is a ruby script with all the commands and a pdf is available on the Australian electric car forum with all the commands The ruby script is for connecting a device called a Rasberry PI to other devices for monitoring. It can also be used as a mini router for streaming movies in your house with an application called Plex. In other words a DLNA server. Quote Link to comment Share on other sites More sharing options...
John Posted August 29, 2015 Share Posted August 29, 2015 Oh I thought it was a serial library, written for ruby, should be cross platform? require 'serialport' require 'axpert_rs232' # => Set your serial port location, ls /dev/ and search for something that makes sense serial = SerialPort.new('/dev/tty.usbserial', 2400, 8, 1, SerialPort::NONE) # => Show available commands AxpertCommands.constants # => Some current device status info AxpertCommands::DEVICE_STATUS.issue_command(serial) # => Some current device rating info AxpertCommands::DEVICE_RATING.issue_command(serial) # => Set battery type to user agm AxpertCommands::SET_BATTERY_TYPE.issue_command(serial, :agm) Anyway there is still the pdf on the forum Quote Link to comment Share on other sites More sharing options...
John Posted August 29, 2015 Share Posted August 29, 2015 This is the download link, only works with serial, would be interested if anybody finds out how a third party can use the usb. Quote Link to comment Share on other sites More sharing options...
Gnome Posted August 31, 2015 Share Posted August 31, 2015 The USB port is a simple USB -> Serial converter which does not have very good support. I couldn't get it to work in any OS other than Windows. Would highly recommend going with this instead: http://www.takealot.com/trendnet-usb-to-serial-converter/PLID29271821 It works on Mac, Linux, Raspberry Pi (without any extra drivers or setup) and Windows. Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted August 31, 2015 Share Posted August 31, 2015 Welcome Gnome I know you are an old hand on the mybroadband site and we are going to benefit from your input. Chris Quote Link to comment Share on other sites More sharing options...
Gnome Posted August 31, 2015 Share Posted August 31, 2015 Welcome Gnome I know you are an old hand on the mybroadband site and we are going to benefit from your input. Chris Haha, hopefully yes, this forum is a great idea. Would love to see it thrive, thanks Quote Link to comment Share on other sites More sharing options...
Antjhb Posted September 14, 2015 Share Posted September 14, 2015 Hi Everyone i am new to your forum and glad to see so many people with experience in the Axpert series. I have the 5K and installed it around April 15. So far so good no problems. But I am glad to see someone is not happy with the software and would like to communicate with the unit utilising its own protocol commands. has anyone furthered this. thanks Quote Link to comment Share on other sites More sharing options...
Gnome Posted September 14, 2015 Share Posted September 14, 2015 I wrote a library in Ruby which simplifies the whole communication. Ruby is cross platform (eg. Windows, Linux, Mac) and you would only need to install: Ruby Ruby-gems Then install the following gems: serialport axpert_rs232 Both are documented and supported on ALL OSs (Worked for me on both my Mac and Raspberry Pi) I'm super busy at work so I haven't been able to finish my application which would give you a web front-end for that library. I tested it using a USB -> Serial converter and I'm still using it. At this point what I have is: I wrote an application that dumps the Axpert current device status every 2 seconds into a file. This file keeps being updated and rotate every hour. Then I used a simple web-application that polls that file for changes and makes it available. Lastly I used a simple AJAX call with a static HTML page and chart.js to draw some data. All of it is very hacky at this point so I don't want to release it yet. But when I'm done hopefully you can get a web interface of your power usage over time. When you were on battery and when on grid power. How much is being used by what. What are the temperatures Emails when you go on grid/off grid/loss of grid. Nice pretty graphs for everything. The HTML part takes a really long time to be honest and it bogs me down On my Raspberry Pi I installed it as follows: sudo apt-get install ruby-dev sudo gem install serialport sudo gem install axpert_rs232 After that everything was working. On my Mac I didn't need to do anything except install serialport and axpert_rs232. Haven't tested on Windows (honestly I'm lazy, I hardly use Windows anymore) Quote Link to comment Share on other sites More sharing options...
Antjhb Posted September 15, 2015 Share Posted September 15, 2015 Hi Gnome Thanks for the reply. what is bogging me down is the CRC part. Dont kill yourself laughing but I use Visual basic 2012. I can communicate with the inverter except i cannot get it write to send the correct CRC commands with the Q commands etc But I will look into Ruby. maybe time for changes Quote Link to comment Share on other sites More sharing options...
Eugene Posted September 15, 2015 Share Posted September 15, 2015 The older Axperts have the RJ45 RS232 ports, whereas the newer models are USB (plug and play). Will your software be compatible with both ?. Quote Link to comment Share on other sites More sharing options...
scottwday Posted September 15, 2015 Share Posted September 15, 2015 Hi Gnome Thanks for the reply. what is bogging me down is the CRC part. Dont kill yourself laughing but I use Visual basic 2012. I can communicate with the inverter except i cannot get it write to send the correct CRC commands with the Q commands etc But I will look into Ruby. maybe time for changes I fed my C# CRC code through an automatic code converter... Who knows, maybe it'll work Imports System.Collections.GenericImports System.LinqImports System.TextImports System.Threading.TasksNamespace InverterEmulator ''' <summary> ''' Calculates the CRC for the inverter ''' </summary> Public Class CRC16 ''' <summary> ''' Ported from crc.c: http://forums.aeva.asn.au/forums/pip4048ms-inverter_topic4332_page2.html ''' </summary> Public Shared Function Calculate(pin As Byte()) As UShort Dim crc As UShort Dim da As Byte 'INT8U far *ptr; Dim ptr As Byte Dim bCRCHign As Byte Dim bCRCLow As Byte Dim len As Integer = pin.Length Dim crc_ta As UShort() = New UShort() {&H0, &H1021, &H2042, &H3063, &H4084, &H50a5, _ &H60c6, &H70e7, &H8108, &H9129, &Ha14a, &Hb16b, _ &Hc18c, &Hd1ad, &He1ce, &Hf1ef} crc = 0 For index As Integer = 0 To len - 1 ptr = pin(index) da = CByte(CByte(crc >> 8) >> 4) crc <<= 4 crc = crc Xor crc_ta(da Xor (ptr >> 4)) da = CByte(CByte(crc >> 8) >> 4) crc <<= 4 crc = crc Xor crc_ta(da Xor (ptr And &Hf)) Next 'Escape CR,LF,'H' characters bCRCLow = CByte(crc And &Hff) bCRCHign = CByte(crc >> 8) If bCRCLow = &H28 OrElse bCRCLow = &Hd OrElse bCRCLow = &Ha Then bCRCLow += 1 End If If bCRCHign = &H28 OrElse bCRCHign = &Hd OrElse bCRCHign = &Ha Then bCRCHign += 1 End If crc = CUShort(CUShort(bCRCHign) << 8) crc = crc Or bCRCLow Return crc End Function End ClassEnd Namespace Although, if you just want to request messages you could hard code the CRC into the request. Here's a capture of the traffic between WatchPower and the inverter, just copy/paste in the request strings and you should be good to go. https://github.com/scottwday/InverterEmulator/blob/master/doc/Capture.txt?raw=true Quote Link to comment Share on other sites More sharing options...
