Hybrid inverter startup query
Fazil
Hi this is my first post but have been browsing and learning for some time so thanks to the plethora of information available.
Now my silly question: How can i startup a hybrid inverter without batteries present? Can a hybrid like an Axpert MKS for example startup from grid alone?
Thanks and criticism is welcome :)
@Fazil,
Some inverters require the presence of 48V for startup and continued operation, as the electronics are powered from this source, like an Axpert. Infini and many other
However, I'm sure you can start an Axpert from a 48V PSU, if you have one and haven't gotten around to acquire some batteries.
Also, there are inverters that do not require 48V for operation, but it is obvious, they won't act as an UPS when the Grid drops.
AFAIK, the "Hybrid" refers to the inverters ability to blend 3 different sources (battery, PV & Grid) seamlessly to provide the load (i.e. you don't notice the change over, as at least 2 sources need to be present) - they are referred to as "True Hybrids"
and normal "Hybrids" are like the Axpert, who physically switches (via relay) between Grid/PV/Batteries.
Lots of suppliers use this term very loosely, probably as marketing jargon.
So do your research many times, and buy once.
