  • 0
SOLVED: Can anyone identify this solar mount? (Its a K2 MICRO RAIL CSM 25)
rgt.dnl
Question
Posted (edited)
***SOLVED***
ITS A K2 MICRO RAIL CSM 25 BRACKET.
MicroRail CSM 25 Set (k2-systems.com)
Hello, I need to identify this solar mount (IBR roof, with adapter for corrugated roof). I have googled and reverse image searched but had no joy. Plenty of brackets out there but I can't find this exact one. Taking a punt to see if the human googles out there can help. May thanks in advance.
Follow-up question: If I cannot identify this bracket, would it be possible to use another bracket on my existing install (e.g. renusol) or would that cause potential misalignment with adjacent panels using the bracket pictured?. Put another way are most brackets similar to this (more or less) the same in dimensions?
Approximate dimensions are:
  • 240mm (L)
  • 35mm (W)
  • 24mm (H) (without adapter plate for corrugated roof)
  • 30mm(H) (with adapter plate for corrugated roof)
Edited by rgt.dnl
Solved question
2 answers to this question
Answer this question...
