Sunsynk Powerflo card Home Assistant Issue
Zeus-JKR
Hi Guys
I have searched and cannot find and answer.
Why wouly my grid charge show on Non Essentials?
When I click on the grid icon I get the below and I cannot change it.
select.deye_sunsynk_sol_ark_generator_connected_to_grid_input
type: custom:sunsynk-power-flow-card
cardstyle: full
show_solar: true
battery:
  energy: 0
  shutdown_soc: 20
  show_daily: true
solar:
  show_daily: true
  mppts: 2
load:
  show_daily: true
grid:
  show_daily_buy: true
  show_daily_sell: false
  show_nonessential: true
  invert_grid: true
  grid_name: Eskom
entities:
  use_timer_248: sensor.deye_sunsynk_sol_ark_toggle_system_timer
  priority_load_243: switch.deye_sunsynk_sol_ark_toggle_priority_load
  inverter_voltage_154: sensor.deye_sunsynk_sol_ark_ac_output_voltage
  load_frequency_192: sensor.deye_sunsynk_sol_ark_ac_output_frequency
  inverter_current_164: number.deye_sunsynk_sol_ark_max_grid_charge_current
  inverter_power_175: sensor.deye_sunsynk_sol_ark_load_power
  grid_connected_status_194: select.deye_sunsynk_sol_ark_generator_connected_to_grid_input
  inverter_status_59: sensor.sunsynk_overall_state
  day_battery_charge_70: sensor.deye_sunsynk_sol_ark_battery_energy_in
  day_battery_discharge_71: sensor.deye_sunsynk_sol_ark_battery_energy_out
  battery_voltage_183: sensor.deye_sunsynk_sol_ark_battery_voltage
  battery_soc_184: sensor.deye_sunsynk_sol_ark_battery_state_of_charge
  battery_power_190: sensor.deye_sunsynk_sol_ark_battery_power
  battery_current_191: sensor.deye_sunsynk_sol_ark_battery_current
  grid_power_169: sensor.deye_sunsynk_sol_ark_grid_power
  day_grid_import_76: sensor.deye_sunsynk_sol_ark_grid_energy_in
  day_grid_export_77: sensor.deye_sunsynk_sol_ark_grid_energy_out
  grid_ct_power_172: sensor.deye_sunsynk_sol_ark_grid_power_ct
  day_load_energy_84: sensor.deye_sunsynk_sol_ark_load_energy
  essential_power: none
  nonessential_power: none
  aux_power_166: sensor.sunsynk_aux_power
  day_pv_energy_108: sensor.deye_sunsynk_sol_ark_pv_energy
  pv1_power_186: sensor.deye_sunsynk_sol_ark_pv_power_1
  pv2_power_187: sensor.deye_sunsynk_sol_ark_pv_power_2
  pv1_voltage_109: sensor.deye_sunsynk_sol_ark_pv_voltage_1
  pv1_current_110: sensor.deye_sunsynk_sol_ark_pv_current_1
  pv2_voltage_111: sensor.deye_sunsynk_sol_ark_pv_voltage_2
  pv2_current_112: sensor.deye_sunsynk_sol_ark_pv_current_2
inverter:
  autarky: power
Hi @Zeus-JKR
You have not provided a sensor for `nonessential_power`. The card calculates this using the formula nonessential = grid_ct_power_172 - grid_power_169. Your grid power is 0 and grid_power_169 is 464W.  You can either provide your own sensor for nonessential_power or make sure that the sensor you are using for grid_power_169: sensor.deye_sunsynk_sol_ark_grid_power is the expected measurement point. Have a look at the docs https://slipx06.github.io/sunsynk-power-flow-card/configuration.html and existing closed issues https://github.com/slipx06/sunsynk-power-flow-card/issues?q=is%3Aissue+is%3Aclosed and discussions https://github.com/slipx06/sunsynk-power-flow-card/discussions for further help and info.
