Zunaid Posted June 30 Share Posted June 30 I have just installed a geyser wise thermostat and panel and notice that it using the element to heat the water to 58 degrees and after an hour or and hour and a half the temperature in the geyser dropped to 45 degrees. Any guidance please Quote Link to comment Share on other sites More sharing options...
Scorp007 Posted July 1 Share Posted July 1 (edited) 18 hours ago, Zunaid said: I have just installed a geyser wise thermostat and panel and notice that it using the element to heat the water to 58 degrees and after an hour or and hour and a half the temperature in the geyser dropped to 45 degrees. Any guidance please Thermostat switches off when water around it is at 58. Then this water moves around to the top and after some time the temp around element drops to 45. Very normal. It is called stratification=layers. Edited July 1 by Scorp007 Quote Link to comment Share on other sites More sharing options...
