Solar newbie77 Posted July 10 Share Posted July 10 Hi , any help would be appreciated, installed today, we have 10 430 watt panels connected but no solar generation is shown.we have batteries to connect but not connected yet , so have selected no battery in battery set up menu Quote Link to comment Share on other sites More sharing options...
Solar newbie77 Posted July 10 Author Share Posted July 10 My sparky has placed the CT coil here, should it be before the electric meter or is it ok? Quote Link to comment Share on other sites More sharing options...
Solar newbie77 Posted July 10 Author Share Posted July 10 Any the meter is showing nothing either Quote Link to comment Share on other sites More sharing options...
Scorp007 Posted July 10 Share Posted July 10 1 hour ago, Solar newbie77 said: My sparky has placed the CT coil here, should it be before the electric meter or is it ok? If the fuse at the bottom is the incoming to the old turn meter then the CT direction is wrong. When no battery activated you must have grid available to the inverter for it to work. In your case with no grid shown on prepaid meter the inverter cannot work and it could be that the prepaid went into tamper mode. Not sure how the meters indicate tamper mode. It could also be meter specific by having an alarm on or red LED. Solar newbie77 1 Quote Link to comment Share on other sites More sharing options...
TaliaB Posted July 10 Share Posted July 10 2 hours ago, Solar newbie77 said: .we have batteries to connect but not connected yet , so have selected no battery in battery set up What i don't understand why would you try to run the inverter with incomplete installation? There is a specific startup procedure in the Sunsynk manual, i would suggest your sparkie familiarize himself with the content! Power on Sequence: 1. Switch on AC 2. Press Start Button 3. Switch on Battery and battery breaker 4. Switch on the DC (PV Isolator) Solar newbie77, Jacques Ester and Scorp007 2 1 Quote Link to comment Share on other sites More sharing options...
