Paul.Chari Posted July 19 Share Posted July 19 Hello I believe I might have finally understood some sunsynk settings after countless video watching and note taking and manual reading. Please could I get corrections on my sheet. I know there are more settings but we all need a base line. Once is correct, I'll try get some friends to do Afrikaans, Zulu and Sotho versions. Time Start Time End SOC Solar Priority Percentage Grid-not ticked Genrator-not ticked Percentage Grid-ticked Genrator-not ticked Percentage Grid-not ticked Generator-ticked Percentage Grid-ticked Genrator-ticked Start of slot config End of slot Config Charge Percent Use battery until value then grid takes over Use battery until value then grid charges till value Use battery until value, then generator charges till value User battery until value, then grid supported by generator charges till value Solar charges battery to 100 when available Solar charges battery to 100 when available Solar charges battery to 100 when available Solar charges battery to 100% when available Solar contributes to load when available Solar contributes to load when available Solar contributes to load when available Solar contributes to load when available EXAMPLE BELOW EXAMPLE BELOW EXAMPLE BELOW EXAMPLE BELOW 0000 1000 100% Battery Grid on, no battery unless grid off, solar charge only Grid on, no battery unless grid off, Grid and Solar charge Grid on, no battery unless grid off, Generator and Solar charge Grid on, no battery unless grid off, Grid then Generator and Solar charge 1000 1500 80% Battery Grid on, battery support as long as over 80%, solar charge only Grid on, battery support as long as over 80%, Grid charge to 80%, Solar charge to 100% Grid on, battery support as long as over 80%, Generator charge to 80%, Solar charge to 100% Grid on, battery support as long as over 80%, Grid then Generator charge to 80%, Solar charge to 100% 1500 1800 100% Battery Grid on, no battery unless grid off, solar charge only Grid on, no battery unless grid off, Grid and Solar charge Grid on, no battery unless grid off, Generator and Solar charge Grid on, no battery unless grid off, Grid then Generator and Solar charge 1800 2000 100% Battery Grid on, no battery unless grid off, solar charge only Grid on, no battery unless grid off, Grid and Solar charge Grid on, no battery unless grid off, Generator and Solar charge Grid on, no battery unless grid off, Grid then Generator and Solar charge 2000 2200 80% Battery Grid on, battery support as long as over 80%, solar charge only Grid on, battery support as long as over 80%, Grid charge to 80%, Solar charge to 100% Grid on, battery support as long as over 80%, Generator charge to 80%, Solar charge to 100% Grid on, battery support as long as over 80%, Grid then Generator charge to 80%, Solar charge to 100% 2200 0000 80% Battery Grid on, battery support as long as over 80%, solar charge only Grid on, battery support as long as over 80%, Grid charge to 80%, Solar charge to 100% Grid on, battery support as long as over 80%, Generator charge to 80%, Solar charge to 100% Grid on, battery support as long as over 80%, Grid then Generator charge to 80%, Solar charge to 100% Quote Link to comment Share on other sites More sharing options...
GreenFields Posted July 19 Share Posted July 19 I think you have the gist of it, though you might struggle to do solar charging at midnight. Quote Link to comment Share on other sites More sharing options...
Paul.Chari Posted July 19 Author Share Posted July 19 3 hours ago, GreenFields said: I think you have the gist of it, though you might struggle to do solar charging at midnight. Thank you. midnight solar might be a thing in the future. Quote Link to comment Share on other sites More sharing options...
