BodoM Posted July 21 Share Posted July 21 Hi all, The "back to AC" setting on my Growatt inverter (SPF5000-ES) cannot be raised from the current 49%. I'd like to make it 70%. I'm using the menu settings directly on the inverter, so any tips to "trick" the inverter would be appreciated. Quote Link to comment Share on other sites More sharing options...
Antonio de Sa Posted July 21 Share Posted July 21 2 hours ago, BodoM said: Hi all, The "back to AC" setting on my Growatt inverter (SPF5000-ES) cannot be raised from the current 49%. I'd like to make it 70%. I'm using the menu settings directly on the inverter, so any tips to "trick" the inverter would be appreciated. What is the setting on parameter 13 ? parameter 12 has to be lower that 13. Quote Link to comment Share on other sites More sharing options...
