rizwan Posted July 30 Share Posted July 30 Hello everyone i need sako sunpolo 5kw frimware version main cpu 00072.10 and do not show secondary cpu version in watchpower plz help me Quote Link to comment Share on other sites More sharing options...
Coulomb Posted August 1 Share Posted August 1 On 2024/07/30 at 6:35 PM, rizwan said: do not show secondary cpu version in watchpower Since this is a grid-tie model, should you not be using SolarPower monitoring software instead of Watchpower? Quote Link to comment Share on other sites More sharing options...
rizwan Posted August 4 Author Share Posted August 4 Ok I install solar power now and check if it shows or not Quote Link to comment Share on other sites More sharing options...
rizwan Posted August 4 Author Share Posted August 4 Can you give me a picture of the solar power software that you use Quote Link to comment Share on other sites More sharing options...
Coulomb Posted August 5 Share Posted August 5 (edited) I don't use Solarpower or Watchpower myself. I think the easiest way to download it is from mppsolar.com under support or downloads. I didn't think that using the wrong one would work at all. Looks like it at least partially works. Edited August 5 by Coulomb Quote Link to comment Share on other sites More sharing options...
Tarek Yag Posted August 5 Share Posted August 5 6 hours ago, Coulomb said: I didn't think that using the wrong one would work at all. Looks like it at least partially works. You are right, the wrong app actually does not work at all... @rizwan are you connecting your inverter to your PC through a USB cable? If so, it won't show "Secondary CPU version", try connecting through USB to Serial and it should work fine. This is a known bug for me! Recommended: Make sure that you're using a recent version of WatchPower. Visit mppsolar.com website as @Coulomb suggested to get the latest release. Quote Link to comment Share on other sites More sharing options...
Coulomb Posted August 6 Share Posted August 6 6 hours ago, Tarek Yag said: are you connecting your inverter to your PC through a USB cable? If so, it won't show "Secondary CPU version", try connecting through USB to Serial and it should work fine. This is a known bug for me! I would not have thought it made any difference. Interesting. Tarek Yag 1 Quote Link to comment Share on other sites More sharing options...
