Aziz11 Posted August 24 Share Posted August 24 Hi all, My Luxpower SNA5000 inverter is working well, but I noticed that with good PV input voltage, the batteries are also feeding into the utility. During load shedding times, it sometimes runs out of power. I need the best settings for the battery to charge by PV and stay on standby until load shedding hours. Please assist me with some settings. I will be thankful. Quote Link to comment Share on other sites More sharing options...
Scorp007 Posted August 24 Share Posted August 24 2 hours ago, Aziz11 said: Hi all, My Luxpower SNA5000 inverter is working well, but I noticed that with good PV input voltage, the batteries are also feeding into the utility. During load shedding times, it sometimes runs out of power. I need the best settings for the battery to charge by PV and stay on standby until load shedding hours. Please assist me with some settings. I will be thankful. Show us a graph of the grid use, battery SOC, load and PV for say a whole day. Quote Link to comment Share on other sites More sharing options...
Aziz11 Posted August 24 Author Share Posted August 24 Quote Link to comment Share on other sites More sharing options...
GMAC Posted August 24 Share Posted August 24 Show your setting please Quote Link to comment Share on other sites More sharing options...
Aziz11 Posted August 25 Author Share Posted August 25 Quote Link to comment Share on other sites More sharing options...
GMAC Posted August 25 Share Posted August 25 Can you post application setting as well please Quote Link to comment Share on other sites More sharing options...
GMAC Posted August 25 Share Posted August 25 Try these setting but leave take load together on . Quote Link to comment Share on other sites More sharing options...
UDC Posted August 26 Share Posted August 26 change your EOD from 50% to a higher value.....currently its set to use from battery until 50% then use from eskom Quote Link to comment Share on other sites More sharing options...
DeezGP Posted September 28 Share Posted September 28 Hi all. I hope you are all well. I too have this issue. I have 2 greenrich batteries and 2 sna5000's. This worked perfectly for a while and then all of a sudden I found this issue. I know luxpower had quite a fee updates so I'm wondering if there is a new setting that needs to be updated. I can see in my monitoring app thay the battery is discharging and if I reduce the load by switching off the heat pump and pool pump it reduces the pv power draw and still continue to discharge the battery. If I switch the loads back on, it will draw from the pv but still continue to discharge the battery. Any help would be great. Thank you Quote Link to comment Share on other sites More sharing options...
