TaliaB Posted August 25 Share Posted August 25 I was asked by a client about the difference between RCT 3kva vm3 and the Kodak counterpart. Is there internally any diffrence or is it just a rebranded Voltronic. Basically which inverter to choose RCT or Kodak? Maybe @Coulomb would know if the internal parts are identical (motherboard ect) Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Coulomb Posted August 26 Share Posted August 26 (edited) 23 hours ago, TaliaB said: the difference between RCT 3kva vm3 and the Kodak counterpart. They are the same thing, made in the same factory, just with different branding. Clones and workalikes however are different; they are made by other manufacturers, often use Voltronic firmware illegally (sometimes resulting in a fault code that stops operation after some weeks), and are of dubious and unknown quality. Telling a clone from a genuine model can be difficult. For RCT and Kodak specifically, these are almost certainly genuine, though you never know if one day these resellers might decide to go with a cheaper clone that appears to be good value (on the surface). See Do I Own a Clone? for clues. Edited August 26 by Coulomb Quote Link to comment Share on other sites More sharing options...
Scorp007 Posted August 26 Share Posted August 26 3 hours ago, Coulomb said: They are the same thing, made in the same factory, just with different branding. Clones and workalikes however are different; they are made by other manufacturers, often use Voltronic firmware illegally (sometimes resulting in a fault code that stops operation after some weeks), and are of dubious and unknown quality. Telling a clone from a genuine model can be difficult. For RCT and Kodak specifically, these are almost certainly genuine, though you never know if one day these resellers might decide to go with a cheaper clone that appears to be good value (on the surface). See Do I Own a Clone? for clues. Thanks for this reply. @TaliaBalso sends a thank you. Quote Link to comment Share on other sites More sharing options...
TaliaB Posted August 26 Author Share Posted August 26 (edited) @Coulombthanks for the info so basically it is difficult to identify a clone with inferior components. There is a few tell tales in your link"Do i own a Clone. Much appreciated and thanks to @Scorp007 relaying my message i am back online. Edited August 26 by TaliaB Scorp007 1 Quote Link to comment Share on other sites More sharing options...
