vvakie Posted August 28 Share Posted August 28 Hi guys, I have a MaxxPower branded inverter (Voltronic Infini Vii) with RS232 port. There are no RS485J ports or Li Ion option in the inverter firmware. I want to connect this inverter with the BMS of my Nesr 100 AH 51.2 KWh battery. Is there any way for me to do so? Or will I have to upgrade my hardware. I'm looking for newer Li Ion supported firmware for my inverter and hoping that one of you have tried converting RS232 to the RS485J and somehow made it work! Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
Douw G. Gerber Posted August 29 Share Posted August 29 You could also just configure it using voltages. Can you provide some more info on the battery? Quote Link to comment Share on other sites More sharing options...
vvakie Posted August 29 Author Share Posted August 29 its been 5 months I'm using lithium lipo4 from Narada, its model is nesr currently I'm using under the setting of user define my settings are: bulk charging at 54.4v float charge at 54v low voltage change over at 51v low voltage cut off at 48v charging amps @20 (takes about 3-5 hours and 7kwh to get full) but with no communication b/w battery and inverter I don't have any idea what're the cell voltages and there differences in mv if any. I have PBMS software but don't know to to connect the battery with pc or which port and cable to use. Quote Link to comment Share on other sites More sharing options...
