Kevin147 Posted September 1 Share Posted September 1 I create a Station in Africa. Then I add a Dongle. All fine, but doesn't show a Device. When I change the Cluster from Africa to Asia, I see the Device. Where and how do I change this, so that the Device reflects under Africa? Is it something that needs to be changed within the Dongle or the Inverter? Quote Link to comment Share on other sites More sharing options...
UDC Posted September 2 Share Posted September 2 are you using the app on phone or web page, on the web page if you go into maintenance, select Read, then scroll to the bottom, check server Ip and change that to Africa and select Set. Quote Link to comment Share on other sites More sharing options...
