Mimi Posted September 9 Share Posted September 9 Hy, I have Deye SUN-6k-SG03Lp1-Eu with Battery ZTE r311. Battery ia not detected. Cable betwen inverter and battery: pin 1 from battery to pin 2 inverter, pin 2 battery to pin 1 inverter, shunt betwen pin 3 and 8 on battery side. Cable is conected on port out on battery and rs485/bms on inverter. in advanced function on inverted i selected slave with Modbus Sn 01, Battery mode lithium, Lithium mode 12. Can you help me Quote Link to comment Share on other sites More sharing options...
HendrikBigChief Posted September 10 Share Posted September 10 (edited) On 2024/09/09 at 9:57 AM, Mimi said: Hy, I have Deye SUN-6k-SG03Lp1-Eu with Battery ZTE r311. Battery ia not detected. Cable betwen inverter and battery: pin 1 from battery to pin 2 inverter, pin 2 battery to pin 1 inverter, shunt betwen pin 3 and 8 on battery side. Cable is conected on port out on battery and rs485/bms on inverter. in advanced function on inverted i selected slave with Modbus Sn 01, Battery mode lithium, Lithium mode 12. Can you help me For RS485, I believe you need to connect pins 7 & 8 straight. For CAN, I believe it is pins 4 & 5 straight. Also ensure no other pins are connected as they can cause interference. Edited September 10 by HendrikBigChief Quote Link to comment Share on other sites More sharing options...
Mimi Posted September 12 Author Share Posted September 12 On 2024/09/10 at 11:58 AM, HendrikBigChief said: For RS485, I believe you need to connect pins 7 & 8 straight. For CAN, I believe it is pins 4 & 5 straight. Also ensure no other pins are connected as they can cause interference. I try pin 7,8 on inverter side and 1,2 on battery side but not work Quote Link to comment Share on other sites More sharing options...
HendrikBigChief Posted September 12 Share Posted September 12 5 hours ago, Mimi said: I try pin 7,8 on inverter side and 1,2 on battery side but not work It needs to be the same pins on both ends, 7 to 7 and 8 to 8. The wires need to be twisted, for example use orange and orange-white wires that are twisted together Quote Link to comment Share on other sites More sharing options...
Scorp007 Posted September 12 Share Posted September 12 4 hours ago, HendrikBigChief said: It needs to be the same pins on both ends, 7 to 7 and 8 to 8. The wires need to be twisted, for example use orange and orange-white wires that are twisted together Great advice to always use a twisted pair and not a wire each from 2 twisted pairs. A twisted pair will reduce interference. Quote Link to comment Share on other sites More sharing options...
Mimi Posted September 13 Author Share Posted September 13 (edited) 14 hours ago, Scorp007 said: Great advice to always use a twisted pair and not a wire each from 2 twisted pairs. A twisted pair will reduce interference. I try but not work. On zte r311 pin 1 is A and pin 2 Is B, pin 3 is conected with pin 7 on battery side. On original comunication cable with pc is same. So i made same cable on batery side and on iverter side i put pin 7 for A and 8 for B. Batery pin 1 to inverter pin 7, battery pin 2 to inverter pin 8. On battery sife cable is conected on port In and Resistence (original resistence from zte) on port out. Also, in deye inverter i have this setup: Battery settings: lithium mode 12, batery mode lithium. Advanced function: Modbus sn 01 and slave. With same pins on batery side, batery is visible in pc bms tool. It is posible to be address? In bms tool batery have address 01 like modbus sn. In deye inverter cant put modbus sn 00 Edited September 13 by Mimi Quote Link to comment Share on other sites More sharing options...
