Hi Guys
I do not know how to compare batteries except for the obvious duty cycles.
Ritar DC12-100
Description: http://www.ritarpower.com/battery/Energy Storage Battery/DC Series/
 Spec-sheet: http://www.ritarpower.com/upimg/201712415519728.pdf
Ritar RA12-100
Description: http://www.ritarpower.com/battery/Reserve Power Battery/RA Series/
Spec-sheet:  http://www.ritarpower.com/upimg/20177102363419.pdf
I can't determine if they are both the same technology. Would anyone be kind enough to compare the two spec sheets and let me know which one is best, please?
Thanks in advance for any help.
EDIT: On further reading, it seems the RA keep a better charge or can run a bit longer under the same load whereas the DC is a bit weaker but can be cycled more. Is my reasoning correct? EDIT
Edited by SolarScholar
