I need help with the BMS in a Victor Max 10.2 kW with a Voltric LIO II-4810E battery
akirayagami
Dear forum, I kindly ask for your help. I recently purchased this Victor Max 10.2 kW inverter, installed the panels, and currently have the battery in USE mode with the specifications provided. I want to acquire another battery of the same type and connect them together via the BMS. If anyone could help me first with the BMS and explain how I could connect more batteries, I would greatly appreciate it,
I haven't connected the WiFi module yet.
I have everything to assemble the cables, but I don't know which pins I should use.
If you could also help me with the configuration and the parameters to modify, I would truly appreciate it.
Edited by akirayagami
Translate the following: I was adding information to the post.
