Hello, I have a shoto SDA10-48100 battery block.
I've been looking into the Battery monitor software myself, and there's been an error where the BMS unit now interprets it as 50Ah and is connected to 15 cells when it's actually 16 cells.
Everyone please help me.
Did this happened overnight or you modify some settings on the BMS settings ?
Looking at the bottom of the screen the BMS part models are different ...
Numbers on the first screen don't make much sense :
- @ 3.3V per cell you are certainly not at 12.1% SOC but closer to 80 ~ 90%.
- 0.0A rated capacity
- 0 cycle
- 0% SOH
Don't mess around with BMS settings & calibration if you don't know what you are doing ...
