Guest Posted September 17, 2015 Share Posted September 17, 2015 O my word: Quote Link to comment Share on other sites More sharing options...
CasualCheetah Posted September 17, 2015 Share Posted September 17, 2015 Whoa!!!!! Quote Link to comment Share on other sites More sharing options...
Guest Posted September 17, 2015 Share Posted September 17, 2015 The one where they push the scaffolding ... did NOT see that one coming. Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted September 17, 2015 Share Posted September 17, 2015 eish.... Quote Link to comment Share on other sites More sharing options...
HyperCut Posted September 18, 2015 Share Posted September 18, 2015 Eish, Ek is nou naar !! The scaffolding looks like DC from the trains ? Quote Link to comment Share on other sites More sharing options...
Guest Posted September 18, 2015 Share Posted September 18, 2015 And to think that all of us here on this forum generate and setup our own electricity 'grids'. Quote Link to comment Share on other sites More sharing options...
Alex Posted September 18, 2015 Share Posted September 18, 2015 The scaffolding scene 'shocked' me to the core! That's gruesome. Quote Link to comment Share on other sites More sharing options...
flatfourfan Posted October 7, 2015 Share Posted October 7, 2015 whoa...............I'll stick to 12v thanks............lmfao!!! Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted October 13, 2015 Share Posted October 13, 2015 I found this this afternoon. I think he is a Canadian version of SuzelleDIY. He was born in Iran. https://www.youtube.com/watch?v=sI5Ftm1-jik. ___ 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted January 30, 2016 Share Posted January 30, 2016 And this is how it looks when you open a fuse under load: Quote Link to comment Share on other sites More sharing options...
___ Posted January 30, 2016 Share Posted January 30, 2016 I found this this afternoon. I think he is a Canadian version of SuzelleDIY. He was born in Iran. https://www.youtube.com/watch?v=sI5Ftm1-jik. Man... I was lucky to learn of the ground probe on the scope on a circuit where I didn't blow anything up (12V 3 amp setup, there was only a bit of a spark). But ever since I've realised just how careful you have to be. Example, yesterday I had the scope on my little STM32 development board. Which is plugged into the laptop via USB. So... should I put the ground probe of the scope on the negative of the devel board? That is wired to the negative of the USB port. Who knows where that goes... so on my little Gigabit netbook that is no problem, doesn't have or need an earth pin. But on the Dell, it has an earth pin, and believe it or not, it seems that's actually connected to the laptop. It seems the negative on the USB port is actually grounded to earth (which is fortunate, imagine if it wasn't)... So now every time I want to measure something, I have to go through that whole process :-) Quote Link to comment Share on other sites More sharing options...
superdiy Posted February 1, 2016 Share Posted February 1, 2016 Man... I was lucky to learn of the ground probe on the scope on a circuit where I didn't blow anything up (12V 3 amp setup, there was only a bit of a spark). But ever since I've realised just how careful you have to be. Example, yesterday I had the scope on my little STM32 development board. Which is plugged into the laptop via USB. So... should I put the ground probe of the scope on the negative of the devel board? That is wired to the negative of the USB port. Who knows where that goes... so on my little Gigabit netbook that is no problem, doesn't have or need an earth pin. But on the Dell, it has an earth pin, and believe it or not, it seems that's actually connected to the laptop. It seems the negative on the USB port is actually grounded to earth (which is fortunate, imagine if it wasn't)... So now every time I want to measure something, I have to go through that whole process :-) Get an isolation transformer for the mains side of your scope and disconnect the earth. Quote Link to comment Share on other sites More sharing options...
___ Posted February 1, 2016 Share Posted February 1, 2016 Get an isolation transformer for the mains side of your scope and disconnect the earth. Yup :-) The other idea I've had: Get a small 12V inverter, run it from the car battery. Thing is, this darn scope chows a 100W of power, so that's probably not the best idea. I must look into this isolation transformer idea again, at least find out what it costs, maybe it's not as bad as I instinctively expect it to be. Scope only cost R1000... so I sort of don't want to spend that much on protecting it :-) Quote Link to comment Share on other sites More sharing options...
superdiy Posted February 1, 2016 Share Posted February 1, 2016 Give Eloff Transformers a call - a 150VA, maybe even a 120VA should do the job. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 9, 2016 Share Posted February 9, 2016 I have NEVER laughed this much ever ... I have been where he is, a FEW times to many. https://www.facebook.com/522454457816173/videos/997269480334666/ Quote Link to comment Share on other sites More sharing options...
___ Posted February 9, 2016 Share Posted February 9, 2016 I have NEVER laughed this much ever ... I have been where he is, a FEW times to many. https://www.facebook.com/522454457816173/videos/997269480334666/ Same dude Chris posted last week :-) Quote Link to comment Share on other sites More sharing options...
Guest Posted March 9, 2016 Share Posted March 9, 2016 Ok, this guy tried to hold out at 20v ... interesting: Quote Link to comment Share on other sites More sharing options...
Mark Posted March 9, 2016 Share Posted March 9, 2016 "Potential to mess up the experiment" Understatement... ___ 1 Quote Link to comment Share on other sites More sharing options...
___ Posted April 2, 2016 Share Posted April 2, 2016 This came up in facebook feed. Some notes. They have protective gear on, the guy actually stands to the side when he pulls the lever, and by the end when they chuck snow into it the power was apparently already off (because my thought at first was that this is extremely stupid, throwing frozen WATER onto electricity :-) ). Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted December 16, 2016 Share Posted December 16, 2016 Clear enough! Mark, Gnome and superdiy 2 1 Quote Link to comment Share on other sites More sharing options...
