Hi All
Just wanting to check my settings with other Axpert Users:
I have the following:
Axpert 5Kv 48V
200 ah bank - 2x 48V banks (12 x 4 102ah Lead Acid Batteries each)
2x 300W panels
I have following settings:
1    SOL
2    20A
12  48V (default feels to low for me)
13  FUL (don't know what this voltage equates to ???)
16  CSO
26  57.6V (Bulk voltage)
27  54 (Float voltage)
31  Sbe
When I want to equalise the bank I then change 26 from 57.6 to 58.4 (the highest I can go???)
Your thoughts please...
Regards
Mark
What type batteries are you using? Most sla types do not require equalisation. But if you do just set the voltage as required when doing a once off equalisation.
I have Lead Calcium 102 ah deep cycle batteries so would like a higher equalisation but use the Axpert Max of 58.4V setting for a charge cycle around the end of each month.
Regards
Mark
Ok. Does your spec sheet stipulate a particular equalization voltage and time?
No... thats the issue... I think I am close except for the upper limit on the Axpert voltage to 58.4...
Regards
Mark
