Gauteng solar installer recommendations
I'm looking for a solar installer recommendations for small residential system based in Gauteng
The installation would need to cover:
  • Axpert type inverter setup (already bought)
  • PylonTech Lithium Ion 3.5kW US3000B battery
  • 3Kw panels to be mounted on a pitched roof
  • Breakers and wiring into DB board etc
  • Electrical COC
6 hours ago, Energy said:
Would love to help. 😆 We can have our seasoned Installer visit you tomorrow if that suits? The income helps the upkeep of the forum. If not interested I fully understand. It's your installation and freedom of choice.
Sincerely
Jason
PM replied
I'm a DIY sort of person, but I would recommend that if you do get an installer, get thme to explain every connection and every setting etc. So if something does go wrong or not perform as expected, you at least have a good idea as to what the problem is, or where to start looking. I did my whole install myself, and then got an electrician to check and connect to the db board.
6 minutes ago, DeepBass9 said:
..., but I would recommend that if you do get an installer,  ...
... I did my whole install myself, and then got an electrician to check and connect to the db board.
Adding another preservative.
I did both, self and installer install.
Installer was cheaper.
Why? He blew less stuff up. 🙂
