Jump to content
Posted
Hi All
I have 2 x 5kwh Freedom Won batteries and 8kw Sunsynck inverter. I have a switch over on my Eskom Incomer circuit breaker. I want to charge my batteries using my 7500w Ryobi generator by just switching over to generator at the Eskom main incommer. I adjusted my battery charging amps to 10A and switched over but my Inverter showed grid as 0w and had no response.
Is it possible to charge my batteries using my generator connected to the main incomer and how do I go about it?
What's the frequency and voltage on the output side of the generator? Under a load. Most inverters in SA will be set for the SA grid code, so if voltage or frequency varies too much the inverter will ignore the generator. The inverters do this for incoming mains as well.
