georgelza Posted April 14, 2019 Share Posted April 14, 2019 Hi guys, so due to roooooof, the plan to go with one x BlueSolar 150/100 MPPT has been changed to 2 x BlueSolar 150/35 MPPT's. One with 6 (3S2P) panels on and the other for now with 3 (3S1P), with an additional 3S added at a later stage (giving me 2 sets of 3S2P, each onto a CC)... and THAT will be all useable area on roof covered. Note, one will catch more early morning, NE, and the Other will be N'ish facing, giving me a wider time frame over which I can harvest PV. @plonkster, @The Terrible Triplett Question, I assume the 2 BlueSolar's can connect to the VenusGX... and will display data as per voltage/amperage and wattage generated by each/individually ? G Quote Link to comment Share on other sites More sharing options...
___ Posted April 14, 2019 Share Posted April 14, 2019 4 hours ago, georgelza said: Question, I assume the 2 BlueSolar's can connect to the VenusGX... and will display data as per voltage/amperage and wattage generated by each/individually ? Correct. The Venus-GX has two vedirect ports (essentially just isolated TTL serial comms), but you can always extend it by plugging a USB hub and using vedirect-usb cables. You can see the individual data from the Device List, eg: You can also give them custom names... I just didn't bother yet, so I have a bit of confusion going on on my system with two 150/35-rev2 models georgelza 1 Quote Link to comment Share on other sites More sharing options...
