edmundp Posted October 13, 2015 Share Posted October 13, 2015 Hi All, Need some advice as I am stumped/stupid. I am trying to fiddle around in C# to call the inverter with certain commands. I got the basics going and get the NAK response. (Been a LONG time since I programmed so snails pace.) The problems are as follows: Could someone please help me with the fixed CRC codes to send for the following commands - I know they are calculated but after that remains the same: POP00 = Run off Utility POP02 = Run off Batteries QPIGS QPIRI How on earth do I send these CRC values to the serial port in C# - I have tried serialport.write (send string & hex byte, serialport.writeline (send string as hex translated to char) etc. I get the NAK response if using serialport.writeline("QPIGS") - that obviously should not work, but that proves the port is open and readable. Please? Quote Link to comment Share on other sites More sharing options...
scottwday Posted October 13, 2015 Share Posted October 13, 2015 Here are the commands in hex: POP00: 50 4f 50 30 30 c2 48 0d POP02: 50 4f 50 30 32 e2 0b 0dQPIGS: 51 50 49 47 53 b7 a9 0dQPIRI: 51 50 49 52 49 f8 54 0d This example program works with my inverter: https://github.com/scottwday/AxpertTest/blob/master/Program.cs Quote Link to comment Share on other sites More sharing options...
___ Posted October 13, 2015 Share Posted October 13, 2015 On a unix machine, "man ascii" is your friend :-) Quote Link to comment Share on other sites More sharing options...
Warren Posted October 14, 2015 Share Posted October 14, 2015 //TO SENDSerialPort sp = new SerialPort(); sp.PortName = "COM3"; sp.BaudRate = 2400; sp.DataBits = 8; sp.Parity = Parity.None; sp.StopBits = StopBits.One; sp.Open(); sp.DataReceived += new SerialDataReceivedEventHandler(DataReceivedHandler); sp.ErrorReceived += new SerialErrorReceivedEventHandler(DataErrorReceivedHandler); ProtocolCommand.command = "QPI"; byte[] tx = ProtocolCommand.GetBytes(Encoding.ASCII.GetString(ProtocolCommand.QPI), CRC16.Calculate(Encoding.UTF8.GetBytes(Encoding.ASCII.GetString(ProtocolCommand.QPI)))); sp.Write(tx, 0, tx.Length);//RECIEVE RESPONSESpublic void DataReceivedHandler(object sender, SerialDataReceivedEventArgs e) { var sp = sender as SerialPort; MemoryStream _rxBuffer = new MemoryStream(); bool _gotResponse = false; if ((sp != null) && (!_gotResponse)) { while (sp.BytesToRead > 0) { byte b = (byte)sp.ReadByte(); _rxBuffer.WriteByte(; if (b == 0x0d) { _gotResponse = true; break; } } } _gotResponse = false; _rxBuffer.Position = 0; SetText(Encoding.ASCII.GetString(_rxBuffer.ToArray())); Datalogger.insertRecord(ProtocolCommand.command, Encoding.ASCII.GetString(_rxBuffer.ToArray())); _rxBuffer.Dispose(); } Hope this helps Quote Link to comment Share on other sites More sharing options...
edmundp Posted October 14, 2015 Author Share Posted October 14, 2015 Thanks all. Got it working. Now to parse the data. Quote Link to comment Share on other sites More sharing options...
