November 30, 201510 yr Sodium Ion Batteries This is the 'salt water battery' the world has been waiting for! Now available in NZ the AquionSodium Ion Battery. S-Line products deliver extremely long cycle life, deep depth of discharge and excellent abuse tolerance. The batteries
December 1, 201510 yr I looked at it a while ago. Some things I noted: 1. This takes a LOT of floor space for the same capacity (ie energy density is low). 2. Can't charge or discharge very fast, so you'll need a lot of it to handle peak charge/demand 3. Cost per kwh is comparable to lead acid, but due to point 2 above, initial investment is a barrier to entry.
December 1, 201510 yr Author I see that the 2kw/h can only supply 450 W and can only be charged at 20 A They need to improve the anode and cathode tech
