Mixing panel orientation?
Ingo
I have limited roof space and was wondering if I can mix portrait and landscape panels to fill all available space. The roof is facing NE and with the JA Solar 315 modules it seems it will fit perfectly (I think). The furthest panel is also +-22m to 25m from my DB so would like to keep the voltage as high as possible as not to buy too much expensive thick cable. The idea is to run a Fronius Primo 3.0 with 4mm wire from the panels which gives me <1% loss with them all in series. I know it goes against any aesthetics but it's what I've been dealt with. The drawing is roughly too scale.
Will this work or am I missing something obvious in my calculations?
The orientation makes no difference. How are you going to connect them, all in one string? 4mm2 cable will probably do the job, but I would rather go for so something thicker. The cables on the panels looks like 6 or 8mm2 so Iwould rather use a similar size to that.
The cables on the panels are too short to daisy chain them together in landscape orientation,  so you will need to extend them to join them together.
Edited by DeepBass9
  • 3 years later...
