Haydn Posted December 9, 2015 Share Posted December 9, 2015 Hi All, Just installed Imeon 3.6 and as soon as I initialise grid connection my prepaid trips and after 15 seconds restarts, but with grid connection off. Any ideas ????????? Quote Link to comment Share on other sites More sharing options...
Eugene Posted December 9, 2015 Share Posted December 9, 2015 The prepaid meter is not bi-directional, is the Imeon trying to feed back into the grid ?. Quote Link to comment Share on other sites More sharing options...
Haydn Posted December 9, 2015 Author Share Posted December 9, 2015 Have setting at Backup and no feed back. Quote Link to comment Share on other sites More sharing options...
Eugene Posted December 9, 2015 Share Posted December 9, 2015 I have a Itron ACE9000 prepaid meter, Over Power = switch off after 10sec and reconnect after 2min, Over Power lockout = 5 trip conditions within 30min Quote Link to comment Share on other sites More sharing options...
superdiy Posted December 9, 2015 Share Posted December 9, 2015 Hi All, Just installed Imeon 3.6 and as soon as I initialise grid connection my prepaid trips and after 15 seconds restarts, but with grid connection off. Any ideas ????????? I think something similar happened to Wetkit with his infini. On the infini software there is a setting where you calibrate the grid power - default is 0, but it can be adjusted more positive or more negative. With "feedback" disabled it still feeds back a little (when set to 0) and only when I set mine to -165W it does not feed back anymore. I'm not sure if you have a similar setting on the Imeon, but worthwhile to check. Good luck. ___ 1 Quote Link to comment Share on other sites More sharing options...
Mike Posted December 9, 2015 Share Posted December 9, 2015 if you have a conlog prepaid meter...ask the muni to swop it out for another make. the imeon works well with all the others. the end user can only access the basic settings, for all others back to the supplier Quote Link to comment Share on other sites More sharing options...
