desiji Posted July 25, 2019 Share Posted July 25, 2019 Does anybody know what causes this fault and how can one solve this problem. It beeps every three seconds and temp is way high. am out of the country and could only access remotely Quote Link to comment Share on other sites More sharing options...
GVC Posted July 25, 2019 Share Posted July 25, 2019 Here is the error code... Not exactly sure, but you might find that one or both of your cooling fans are faulty... Coulomb or one of the other boffs should be around shortly to give you a more exact explanation. Quote Link to comment Share on other sites More sharing options...
Coulomb Posted July 26, 2019 Share Posted July 26, 2019 9 hours ago, GVC said: Coulomb What can I say? The fan isn't spinning, according to the measurements. So either the fan is faulty, or the measurement is wrong, or something is stopping the fan from spinning. Perhaps a stick was blown into the fan area. Note that this could be warning 01 or fault code 01 (error 01). In the latter case, most of the inverter stops working; in the former case, it continues working but may overheat. Quote Link to comment Share on other sites More sharing options...
